56cm Pinarello Prince SL
Amazing. And actually quite cheap when you check out all of the componentry.
$3,000
Frame is made of Scandium alloy in which Pinarello call, EXTREME SC 61-10 A.K.E.T (very very light frame). Bike weight as is in photo is only 6.1kgs. Colour Blue and White
Size is center of B/B to center of top tube 56cm, Top tube is 56cm C/C. In photo seat is at 78cm c of B/B to the top of seat.
Cranks: Campagnolo Record pista 170mm track with 52 tooth chain ring
Bottom Bracket: Campagnolo Record Pista carbon.
Handle bars: Deda Newton alloy shallow bent 42 c/c 31.8
Stem: Dead Newton, in which Deda made for Pinarello, So hence the logo on it. 120mm.
Saddle: Fizik Arione Ti rails White. (New Never Used)
Post: Pinarello Carbon 2 bolt clamp.
Wheels: The Zipp 404 with zipp hubs, have only been used 5 times, so very new condition and not cheap
Tyres: Continental Tempo 22 Black singles which are the same age as the wheels.
eBay Listing
Hory sheet that weighs about as much as my hat collecton, fucken cool hey?
