advice on a new pump
Hello,
My current pump is a bit dodge, i’ve had it a while and I’m pretty sure the pressure gauge is out by quite a bit.
I don’t really like the push on nozzles, my last one was great for schrader but bent the cores in presta which eventually breaks them.
What do you guys recon of these,
http://www.cyclingdeal.com.au/buy/high-pressure-bicycle-bike-cnc-alloy-floor-air-pum/ZT-901
They look fairly similar to the Lezyne but a lot less money.
http://www.cellbikes.com.au/GIYO-Hi-Polish-Aluminium-Floor-Pump
Or do the duel head pumps work better.
I’ve had one of these for years and it hasn’t missed a beat. I’ve literally used it hundreds of times without issue. It’s got a 4.5 star rating from 45 reviews so it can’t be too bad. Probably one of the best pumps you’ll get for $40
If you’re bending cores it might be the pump or your technique. I’ve never done it.
I don’t like screw on nozzles because I tend to unscrew the valve core far too often.
Edit: On close inspection, I’ve got an older model Giyo Air Supply with a slightly different head so my experiences might not reflect accurately on this model
So Bigadz your pretty happy with your Giyo, I really like the look of the aloy but might be tempted with the cheaper one. have you bent many cores with yours?
