Anyone running these forks? im keen to run them on an Analog frame, the Ass to ₪₪₪₪ is 30mm longer than analog forks and has 10mm more rake and they are the same weight.
Do you reckon that will fuck up much of the handling? Mostly want them for wank factor but dont want them to be useless to ride.
Cheers,
Undies.
S&M 26" Pitchfork
dont do it dan, it WILL fuck the handling,
30mm a2c and 10mm rake is a HUGE difference.
it will ride like a chopper with that much more a2c than the frame was designed for, you would have to run a 26" front to get it back to what it should be( close to anyway) and then you are just defeating the purpose of getting a fgfs frame that can clear up front with a 700
Cheers Nathanyal, will just get the ANALog fork then.
If you just don’t like the look of the ns fork, which I’m not a fan of, and you really wanna change, look at one of the 700c forks like the thrasher, bmw launchpad, bruiser etc all have a2c of around 400-410
