Melbourne is becoming colder and wetter, and it’s making me think about what sort of tyres to be running this winter.
So what’s the latest and greatest?
I’ve had good experiences with Schwalbe Durano Plus and Continental Gatorskins.
But what is the best tyre diameter?
I’ve used 25c diameter tyres in the wet which were great, but I’ve never used 28c on a road bike. Am I going to fit 28c on my steel roadie, or do you think 25c is more than enough?
Is there such a thing as a Kevlar (folding, light) 28c tyre?
For light, folding, 28mm; Grand Bois! Made in 23/26/28/30mm. The 28s measure 29mm I think. I have 26s and quite like them. They’ll be at Fed Sq tonight if you will.
(email me… tyres and headsets.)
Don’t forget to put some vernier calipers on your tyres to see if they’re really 28mm too. My 26mm GB tyres are wider than some “28mm” tyres I have.
so i just put my new wheels on my new frame and there’s not enough clearance on the front fork. i’m guessing dropping from 700x23’s on the front to 700x19’s is a bad idea for riding on the road?
slightly off topic but advice is always greatly appreciated
i had a 19mm on the front for a while. it was ok. i mean, you sure felt the bumps, and had to be a bit more careful around the corners, but they were pretty fast.
now i have 32mm front and rear. it’s a little different.
Ah yes I remember you recommended these before. Quite good value if I recall. How is the sticky-ness in the wet?
I have found that Schwalbe do a 28c Durano (vanilla, not Plus). Might be a go
