I know Campy have different size axles therefore different sized nuts, but are Formula / Velocity / Suntour all the same size?
Also, are they the same size front and rear?
I need some for some Suntour Sprint hubs and I thought about using some Formula nuts.
I think front is 9mm & rear is 10mm.
Not sure on the tpi of suntour sprint but i remember i found a chart on sheldon a while back, ill try dig it up
edit: Suntour = 10mm x 1mm & 9mm x 1mm according to this Harris Cyclery Bicycle Hub Axles
Here you go: (scroll down)
You’re interested in axle diameter and threading.
Formula etc should be 9x1 and 10x1mm (F / R). This should match Shimano / Suntour. Campagnolo and clones and Sovos/Suzue are two other sizes.
sure are dude
but if they’re not, they’re cheap so you’re not wasting any coin.
Thanks!
Off to the bike store now…
