Hey there,
I need a new helmet. I have a very big head. Current helmet is a Lazer Helium which I really dig, but just wondering if anyone else out there with a huge head has any recommendations.
My head is pretty much 62cm, which is a cm bigger than most brands go. eg Giro only just fits with thin pads and the adjustment right out, but is uncomfortable.
So, suggestions? I may just end up with another helium…
I have a 61 cm head and current helmet is a Lazer Sphere. My second one, and the one i had before fitted larger. I sanded a couple mm off the front. Fits ok now.
Have a specialized prevail as well, fit is more comfortable (bigger), its super light weight but it makes me look like Toad and the (lack of) adjustment doesnt really work for me. Kask helmet looks good for size, i like how the rear adjustment mechanism on those can pivot.
I have a huge head and had a giro but it didn’t fit well, Just got the Kask Mojito
It’s a bit to get used to but i love it, Just make sure if you try oe on that you pull the rear craddle all the way down below the back of your skull.
Problem solved: Specialized S-works something-or-other go up to 63cm, and they’ve got some deal on certain helmets that if you bring in your tired old helmet you get $X off the price. So I did that. I now have a very large, very nice fitting S-works helmet to pick up tomorrow when I drop my old one in.
