Not sure if everbody knows this but I had some campag training yesterday and I found out
#New cyclecross cranks are coming out both 10 and 11 spd
#you can make a 10 spd veloce cass work as a 9 spd if you change some spacers so you can keep that sweet 9sp record bike going
#They are introducing a cheaper cranset which has the axle bonded into the drive side like shimano and F.S.A
Hope this is not old news
I saw some shots from Asian Campag OEM product releases a couple of weeks ago, confirms your training. Also, a Athena 11, Centaur / Veloce 10 available in full alloy, no carbon levers or cranks. Perfect for a classy steel build.
http://www.campyonly.com/rumors/2010/2011_lineup.pdf
Italian Cycling Journal: 2011 Campagnolo, Fact or Fiction?
2011 Campagnolo news!! - GBC
What is different about cyclocross specific cranks?
Compact double, sometimes a bash guard. 34/48T or thereabouts I think.
Yeah it’s about the p.c.d so that you can run a 34 inner ring and a 46t say big ring and yes the all alloy shot’s I saw looked good made me think of a modern Colnago Master campag build.
