seeking advice and opinions on what everyone uses chain device/guide wise for single chainring setups?
1 x 9
I’m using a Paul Chainkeeper on a 1x10.
I’ve used the paul and the mrp xc guides (on xc bikes, not cx), the paul is a lot better at not rubbing at either end of the gear range. The MRP rubbed at both inner and outer unless you put a longer bolt and shim at the rear join of the cage (and I think tomacropod will back me on that?). I’m sure there is heaps of stuff out there, but if you can get a Paul, I can’t see any downside to it. Very easy to set up, easy to set up, easy to clean, chain doesnt come off.
Or use a front derailleur limited off as a ghetto solution.
+1
Dremel off the rear third of the cage for ease of use.
I used a BBG bashguard on the outside and a cheapo deda dog fang on the inside.
bash ring on the outside, “Jumpstop” (<$20 a Abbotsford Cycles) on the inside.
