AL9000
July 20, 2014, 2:39am
#1
32H
non-disc
black
$15.
Here’s the best part though: Comes with internally threaded hollow axle, so you can run a QR, or use the supplied M5 bolts and end caps (like CK fun bolts but smaller) and it’s now a bolt up hub.
sweet!
Click Bike bicycle clearance boutique (Salsa Cycles & All-City Cycles)
droz
July 20, 2014, 4:38am
#2
Had one of these built up for my nature boy so I could use the bolt up hub with a soma rack. Does good.
Yerp, good hub. Have a polo front wheel built up with one.
$10 now. Will buy. Do these dimensions sound right for spoke calcs?
DMR Revolver
Type OLD DL DR WL WR S
Front 100 41.0 41.0 36.0 36.0 2.4
AL9000
July 23, 2014, 8:02pm
#5
I didn’t measure the one I built up, but the dimensions I found (from upgradebikes.co.uk ) and used with success were:
Lightweight and tough, with forged 6061 alloy shell and 7075-T6 alloy axle running on double sealed bearings, use it with QR or supplied bolts.
180g
Hub Dimensions;
Spoke Hole ø 2.6mm,
PCD Left 40mm/ PCD Right 40mm,
Flange Left 36mm/ Flange Right 36mm.
