Chinese Groupsets
You obviously don’t know my area very well because there is plenty of climbing to be had if I want within a 10klm radius. :face_with_tongue:
Foo
I would have thought that going “single” up front would give you bigger jumps between gears? :thinking:
It does. That is why more gears on the cassette is a smart option. It is manageable on the dirt with a slower speed. Ok on the road but the 2 tooth jumps on the cassette at the bottom in the harder gears would annoy me over time. Less of an issue at the other end of the cassette where the gears are easier. The 44t chain ring and 10-45 is acceptable on road but I prefer the 50/34 11-34 on my roadie for the very similar range with narrower gaps.
Removing the FD and inner chain ring allows more clearance on newer gravel bikes as I understand it. On mine it is the DS chain stay that limits it.
I’d expect so on FOA. But I don’t see much evidence on this thread. I only posted about a lower speed groupo as a bit of joke.
There is obviously a most efficient cadence for individuals, but varying it could be good training if the knees don’t have an issue. There is always standing for shorter stints too.
Similar to what I’ve heard with MTBs. More clearance for bigger tyres. It also gives more “real estate” for better suspension design. Having said that, the clearance on my Kona Unit isn’t huge at the chainstays.
Perhaps it’s only a matter of time before more “Roadie” specific 13/14 cog cassettes become available. ???
For example, in 13 speed cassette you could get the following cogs :
11,12,13,14,15,16,17,19,21,23,25,28,32
Surely if used in conjunction with a 50 tooth front chainring, this would give both close ratios and a low enough climbing gear for most roadies and most courses.
I suspect that the absence of a front derailleur gives a fair bit of extra freedom to design stronger and more aero tapering shapes to the lower seat tube in modern (and future) frames.
Band on front derailleurs were no issue to install on tough little skinny frame tubes decades ago.
These days it’s obviously getting more and more problematic/expensive for manufacturers to provide secure mounts for modern front derailleurs on eggshell thick, tapered shape carbon frames
I am not climbing steep stuff in a 50-32! I run 50/34 11-34 on my 12s di2 roadie. Perfect for what I ride with the legs I have. I do occasionally use 34-34. Not often but it is there if/when I need it.
44t ring with a 10-45 on the gravello with road gearing is very similar, due to the 10t allowing a smaller chainring. Just higher cadence changes than I’d like with 2t gaps at the bottom of the cassette. Workable but prefer the 2x due to those bottom of the cassette jumps.
There will eventually be a 13s cassette I can use on the eGR but will probably have a narrower chain. Haven’t spotted one yet, so it can stay as 12s.
The FD mount is no prob on CF frames ime. Just captive nuts in the seat tube where it fits. Have/had multiple CF frames without issue.
Hmmm just browsing for estimated battery life on one charge (300-500km apparently) but spotted this on bikebug and pushys;
LTWOO eRX and eGR Compatibility Guide: Will L-TWOO Electronic Shifting Fit Your Bike? - Pushys LTWOO eRX and eGR Compatibility Guide: Will L-TWOO Electronic Shifting Fit Your Bike? - Pushys
a fair bit more than I paid but I fluked the right time to get it I think. Presumably better warranty support should you need it, buying locally.
It lists 11t as the smallest cog and 50 as the largest for eGR on there. 10-51 is working fine currently on mine, but you couldn’t really go any larger.
That’s very interesting, thanks for posting :+1:.
I got to use my lowest ratio on the gravelo this morning !!
Let’s call it the crawl gear, turned a steep dirt road with a slightly loose dusty/stony surface into a “walk in the park”.
It’s a 13 speed cassette 10-42, and a 38 t chainring. Not a Chinese brand (it’s Campagnolo) but then maybe Marco Polo brought the beginnings of this technology back from China a thousand years ago :wink:
Interestingly, my riding buddy was on his GRX bike with double chainrings. 50/34 ring crankset and 11-36 cassette.
I think that 1 x 13 is a more than reasonable technology for gravel riding.
It will be interesting to see what happens in the Gravel Worlds in WA tomorrow, and what choices are made with the drivetrains etc.
They are big chain rings for a gravel bike.
Must not have standard grx chainset on it. They are 48/31 and 46/30 afaik.
My previous groupo on the Revolt was 11s grx with praxis chainset 48/32 and an 11-36 cassette. I prefer the 12s 1x I have currently on the dirt.
Correct
Yes, I stand corrected, his gravel bike (Giant) is GRX derailleurs but with FSA 48/32 crankset.
He is quite an accomplished rider who has done tough (over 100 km) gravel events such as the Sunday Creek Classic and the Tenterfield Gravel in recent years
I was looking to upgrade my GRX on my gravel bike to electronic. Looked hard at the chinese groupsets. I also wanted carbon wheels with bigger internal width to accomodate 45 mm tyres a bit easier as they bulge a bit and my standard wheels. Also wanted a power meter, because I like toys :slight_smile: Cost was getting up there a little. In the end I bought a new Chinese gravel bike with Di2 for a good price. Lighter, electronic, carbon wheels and a power meter. Rides very nicely.
What did you get?
An X-Lab GT8. First proper gravel ride this morning, does the job well.
where did you buy it from?
From my LBS, WesternPort Bicycle Centre in Hastings Vic.
They sold 3 Di2 versions off their first allocation in a day.
Rode the gravel shop ride this morning with one of those buyers.
I run flats on half my bike and considering using them on my commuter. I have a carbon bike but always ride my steel bikes. I have a disc brake bike but mostly ride rim brakes. I ran tubeless for years but I’m back on tubes.
Everyone is different. Just because you like something doesn’t mean it’s categorically better, or what everyone else wants to use.
Perhaps use the full quote;
Without having ridden electronic it is pretty hard to have an opinion based on experience. I once thought the same and then I rode it. No way am I going back to cable. It is just better in so many ways.
The same can be said about, clipless pedals, carbon frames and wheels, disc brakes, tubeless tyres. Probably even pneumatic tyres. New stuff often faces resistance from traditionalists.
I was commenting on antipathy about electronic groupsets without having even used them.
You have used the stuff you don’t prefer, good for you.
The stuff I mentioned and you quoted, isn’t better or prefered by everyone as not everyone has the same use case. Sure as hell has faced “resistance from traditionalists” however, which appeared to be the case here with electronic groupsets, and it appears they hadn’t actually ridden them.
I believe I qualified those comments in a subsequent reply to the same poster in this thread and did make the point not everyone has the same preferences;
I have and had multiple bikes. Aluminium, steel, CF. Traditional alloy wheels and tubed tyres. CF tubeless. Disc brakes, rim brakes. Electronic gears.
Guess which bikes get ridden the most? I enjoy the feel, comfort, lateral rigidity and speed when I chose to pedal fast, that my modern gear gives me.
Electronic derailleurs are up there as a good innovation ime. They are just nicer to ride for me. I am an enthusiast. I spend alot of time on my bikes. It is what I enjoy doing. Experience riding plenty of different types of bicycles. I ride what I enjoy the most based on that long time sampling different equipment.
You complain about being the lone voice against unnecessary tech on bikes. Plenty on here appreciate older lugged steel framed bicycles. It is what their experiences and preferences lead them to chose. Their passion for bicycles is directed to older tech
Perhaps you are the “lone voice” as you are the only one who seeks to impose your ideals in threads that are clearly about different choices to yours?
