need to cold set a steel frame that’s spaced at 130 to 120mm. to keep it relatively square what is the best way to do this?
bro. just respace your hub bro.
-teenge bro
^Science library computers being put to good use?
I has laptopz so its all good
Outstanding,
Carry on then.
pretty much just stand on it (one side at a time) and get it to 120mm
tie a piece of string from dropout to headtube to dropout
then measure the distance from string to seattube
to be sure the triangles are still even, [figure a].
then get a 10mm bolt and bolt it where your axle goes. do one on each side
then measure the bolt ends (which are where the middle of the hub will be)
to ensure the dropouts are even and not twisted in from bending the triangle [figure b]
when you put your wheel in check that the dropout sits flush against the axle nut
dont do this with a non-steel frame or you might die.
figure a
figure b
yet more contenders for the next fixed.org.au t-shirt design.
YES. i would so wear one
It reminds me of this awesome Don Caballero shirt. In a good way.
LOL good diagrams, makes sense
any compelling reason i shouldnt just space the rear hub? the axle will be long enough.
not really. saves you having to space the next wheel you get? i dunno
Spud you are ON FIRE TODAY!!!1
i ended up just squishing it on the floor
isnt perfect but isnt too far off dead square
good enough for a commuter
Fuck MacGyver! Sheldon Brown is my hero!!
Is this cold setting is A synthetic resin that can harden at normal room temperature without the addition of a hardener.? I am just a little confused about it . Can further more explain it.?
its just a fancy way of saying ‘hey i just bent my frame to fit a smaller hub’. :evil:
but yes there is also cold-setting synthetic resin.
Cold setting is a banana drenched in chocolate source firmly ensconsed in the anus of an endangered blue whale.?* I am so confused. Welcome to the forum.
*beer-o’clock commenced about 7 hours ago.
We need to make an ultimate quotes sticky…
