Had a bit of a search and now I have tyre overload.
I am looking for a set of tyres to commute to work/grind on. Most of my commute will be bitumen with some gravel shoulders - which I will be on when the trucks try to squeeze past (only about 2km).
I don’t like paying more then $50 for a tyre - will be doing lots of online searching.
I can heartily recommend both the Vittoria Hyper Randos and the Schwalbe Kojaks. They’re both fat and fast, and can easily handle a bit of gravel.
The Hypers start at 32c, but the Kojaks go down to 28c and maybe smaller. I’ve been using the Kojaks in a 35 for the last couple of weeks, and they’re bloody unreal, in the wet or the dry.
Gatorskins probably have the best puncture protection, but you lose a little in wet weather grip. That said, I only had a couple of punctures on the hypers in almost 2 years on west sydney roads, and only really once they wore down a fair way.
I have used Schwalbe Marathon Cross for rough gravel touring and lite trails but they are 38’s, they are nice and grippy, no punctures but the rear has worn quite badly (I think cos of all the road riding between dirt/gravel).
I have just got a set of the folding Marathon supremes in 35c for road touring and a little path action, they are pretty nice on road, haven’t taken them off thou.
I have also used Schwalbe cx comps they are 35c too but cheap ($15-18 online plus shipping) but worked fine as a gravel grinder/commuter/path tyre.
Dunno how’d they go fully loaded?
What about schwalbe marathon mondial or extreme?
If you can fit in a 35c with a mud guard it opens up a lot more. . .
I think the latest Schwalbe Kojaks are worth a shot, especially if you’re mostly on tarmac. Resist Nomads in 45 (actual ~40mm) are also good. If you need a little tread, Vittoria Randonneurs have a CX version with some edge knobs.
Kojaks are available in 28c and 32c as well. Keep in mind that the 32c Hypers are pretty fat: you might be best off with 32c Kojaks. (32c hypers are almost as wide as 35c Kojaks…)
I’ve run Resist Nomads in a 35mm (more like 32mm) for the past 3 or so months and I’m very very happy with them.
No punctures (knock on wood), grippy in both wet and dry conditions and look pretty good also.
If I can fit them with mud guards, I’ll put the 45mm ones on when these wear out.
