Corime 4 spoke 8sp rear wheel - Can I turn this into a front wheel/track rear?
Hello All,
I want to turn this:
http://www.fixed.org.au/forums/t18817/
Into a track rear wheel/front wheel, can you please tell me if this is possible?
Kind Regards,
Trigger.
P.S. I meant to write Corima, not Corime, in the title.
Corima make a converter with 3 pins that slot into the hub body which turn it into a tarck rear wheel, it is something like $400
Other than that, befriend a machinist and treat them REAL nice, get them to make something up, keeping in mind that they will hate you afterwards, it would be a bitch of a part to machine up
Cheers, I’ll look into it.
it looks like its a shimano free hub body…
so you should be able to use a ‘Surly fixxxer’ to convert it to track rear. the tubular bit on on the other hand…
This is only for Shimano BRANDED hubs, not a Shimano compatable free wheel.
As BrakeFree said this is the most logical way:
^^ cheers for the correct info.
