hey so when i got my new frame i did not have any spacers,
so being very impatient i cut the tube to fit the frame so it only has like 2mm of like washer things that came with the headset is there anyway i can extend it will http://www.ebikestop.com/pyramid_quill_stem_riser__extender_254mm_dia-57659.php that work ?
thanks
The thing you linked to looks like a quill to threadless adapter. What you need is something different.
See this thread for a solution. Any LBS that carries BBB should either have or be able to get one for you.
Next time, measure twice, cut once.
thanks man helped alot.
