Does such a thing exist and if so, any recommended?
(edit: frame is disc only)
Been trawling and haven’t found anything other than those Topeak things that clip on the seatpost but I might be looking in all the wrong places.
Old Man Mountain do axle mounted. Tubus also do an adapter kit for axle mounting. I have the Tubus on a disc frame and it works great.
Regular panniers plus p-clips? Works great with fenders, should go ok with panniers, maybe not with super heavy loads.
I’ve always backpacked it but I’m considering crossing over to the beardy side. I had to google ‘p-clips’ … s’pose that could work for commuting, just a change of clothes & maybe a lappy.
Axle all the way. Don’t waste time/money faffing about like I did.
You can get them off ebay pretty cheap, eg: Mikalor W1 Steel Epdm Rubber Lined Hose Pipe P Clip Retaining Cable Wire Tube UK | eBay, but probably also at your local hardware.
They hold pretty well.
Think I’ve got a couple spare you can have for nix, Cap’n.
I think I do…I’ll have to check.
Just been out to look it over…as well as discs it’s got sliding dropouts with nuts & bolts & stuff all over them which the axle mounts I looked up probably won’t clear.
I’ve got a topeak one which is awesome. Super commuter DX? Or similar. Super something something X. I’m not 100% sure on the X bit either.
ta
you sure? those old man mountain ones have heaps of clearance
Free loader? Now by Thule
yeah looked those up…system looks good but some $$$ required (typical Thule) $169 for rack, $199 each for the matching Thule Pannier
