I’ve got a Bianchi (Pista) wheelset, I want to run them on a Soma Van Ness, the issue is I think the axle spacing of the Pista is narrower than the Soma because there isn’t much in the way of threads protruding (plus the dropout width of the Soma is thicker). Is there a way to put a longer axle in? It’s not a bad wheelset, but I don’t trust riding it without having the bolts biting on to more threads.
EDIT. Looking at the Soma website, the Van Ness has a spacing of 120mm, I assume this would be the same as the Pista. In that case it must be the thicker dropouts causing the issue. I’m not sure if buying a different wheelset would have a slightly longer axle even if the actual spacing is 120mm.
