maybe a stupid question but, can i use forks Designed for integrated headsets with a frame that has a normal 1 1/8 headset?
thank you
theres no straight answer.
The crown on forks designed for an integrated heat tube, is normally alot bigger than one that is not - so it sits flush with the heat tube.
The larger crown may interfere with the bearings on a standard 1 1/8" headset. it may not. try it and see.
