General Car Thread
Another two of many things to look at. Is the battery old? Is the alternator charging well? I had my motorcycle throw an engine light because the battery was old and it started somewhat strained. Like you, it look stopping somewhere for a while before it went away. Suffice to say I got a new battery. The old one was about 10 years old.
AI helped me diagnose the problem.
Yes, thanks for the tip.
It’s worth looking into, as I’ve had this vehicle for about 5 years and there has been no battery change in that time.
I’m happy to report that it completed the approx 250 km drive back from just north of Tenterfield, to just west of Murwillumbah, without any dramas!
No funny engine warning lights, no loss of power etc. The countryside is beautiful at the moment. Perhaps a bit dry up around Tenterfield way but visually not in obvious drought (yet). Between Lismore and Murwillumbah there hasn’t been much rain at all for some weeks but still looks very green and plenty of Spring colour flowers and foliage.
Heaps of Kangaroos seen on the road north of Tenterfield !
I have an OBDII dongle from Jaycar that I plug into my Forester when it the warning lights come on. Connects to an app on my phone via Bluetooth.
It lets me read the code and see what it is, and clear it if it is minor.
For the Forester it is normally an O2 sensor on bank 1 and my mechanic has confirmed it is a nuisance alert and can be cleared.
Cars of that size these days are not even working at that speed anymore with 7-8 speed variable autos, most are just doing 2,000-2,00rpms at legal highway speeds and with the awesome synthetic oils we have today, if the cars are maintained properly, many little 4cylinder cars are getting up to 400,000kms plus more.
A friend of mine in Grafton used to have a security delivery run from Ballina to Newcastle every 2nd night and return next day, he had a petrol Toyota Highace, 5 speed van, he oil changed it every fortnight and it got him over 1 million kms without a overhaul…I beleive it’s sitting in a Toyota Museum somewhere in melbourne I think he said…so these days, the modern vehicle isn’t working very hard compared to the 60’s and 70’s with 2 to 4 speed manual and autos.
Well, shazbot.
Voided most its juice on the way home last night via a split radiator. Not chancing a car like this (Mk7 GTI) for even 5 minutes without a coolant system. The amount of stuff running off it is insane. Engine cooling, turbo cooling, exhaust manifold cooling, oil cooling, but no trans fluid cooler in the manual box. Being replaced today.
And some people say that modern cars are “so much more reliable than cars were years ago”.
Well perhaps they are a bit more reliable, but not spectacularly so.
My first car was a reliability disaster.
But that was 45 years ago. It was a 1970 Toyota Corona and it had presumably been thrashed and not looked after by its previous owner(s).
But perhaps it was a blessing in some ways. It kept on failing me in various ways to the extent that one day I had a long walk home and decided that if I kept a bicycle in the back seat area it would make life easier. And the rest is history.
years later, I purchased (privately) a 1992 Volvo 940 wagon.
One of my more interesting acquisitions, it was several years old but had only done about 70,000 km. So no warranty and on the first significant “expedition” (big trip) it started to cough and splutter badly driving through a typically heavy downpour on Queensland’s so-called Sunshine Coast.
I thought of course that I had bought a lemon.
But it limped home. And the Volvo mechanic promptly diagnosed a defective spark plug connector (or something like that) and it was a (very) quick fix.
Which brings me to the issue of radiator.
The Volvo mechanic told me that modern cars usually have radiators that are made from plastic, and he recommended that the complete radiator should be replaced every 5 years or so. Because he said that they will eventually start to crack.
But then maybe that advice only applies to European cars from that era !
Good luck with your vehicle.
All the tech introduces so much complexity into what should be a simple system, with the aim of efficiency and emissions. I know I’m not telling people stuff they may not know here, but this is what I tell my (mostly adult) kids, non-car mates, whoever. New coil packs run voltages up to huge numbers. Injectors mist fuel in at big kPa. Plug gaps are incredibly finely tuned. A misfire could now be plug, coil, injector, fuel pump, fuel rail, or even ECU. When the ECU in the GTI picks up a misfire, it will shut down a cylinder if it gets enough instances recorded. And it’s not that big of a margin for shutdown either. It happened on this one, and it was the bolt holding the coil pack in wasn’t fully tightened and it would periodically lose the earth connection and misfire.
