need help working out chainline
hi
Ive been lucky enough to score a nice carbon TT frame with horizontal fork ends from a mate.
seeing i have a set of ambrosio track clincher here I was thinking of building a track bike from this given its geometry
what i need to know is.
I have 120mm spaced fixed hub. the frame is 130mm. easy. i can machine up some alloy spacers to sort that out.
what on earth will the chain line end up at?? what crank & BB do i need??
wheres a good place to buy?
i figured this would be a common conversion.
Spacing out the rear hub won’t affect the rear chainline.
Most track bikes I’ve come across use a 68-108 BB. 68mm being the width of the shell, 108mm being the width/lenth of the axel.
This is a good place to start:
http://www.sheldonbrown.com/chainline.html
standard modern road frame 68mm
its the same frame as this if that helps at all http://www.cycletaiwan.com/shop/components/com_virtuemart/shop_image/product/Matrix_TTR1_fram_48d4848115efa.jpg
ive had a big read on their website today :slight_smile: hes very good. the wheel building things excellent
so a track crank with a 108BB should see me good!
Yep.
Are you planning to fit the parts yourself?
If it turns out you need a 68-113 instead, it might be better to let a shop find that out, as you might not be able to return the other one after you’ve installed it.
Either way, figure out your front chainline first (i.e. once BB and cranks are installed) and then make your rear hub spacers to suit. If you need a 68-113, you might make the left rear spacer longer than the right.
get me straight, your gonna make this:
into a track bike?
are you gonna ride it in the street?
yes gunna make that into a track bike, but for veledrome use only :slight_smile:
geometrys 45 deg on the seat post and steerer. the standard forks a little long in the rake but its stiff as and very light. i basically need to buy a fork and a crank to have a pretty nice track bike so figure its worthwhile.
and hey it was free! (the internal cable routing was screwed up) so why the hell not :slight_smile:
i will grab a 107 and go from there. can alway machine a spacer ring up to bring it out if I need too…
paint it matte black
matte black :slight_smile: great idea
good excuse to fill all the cable and brake holes too.
Wrong.
Spacing the hub has no bearing on chainline. The hub will most likely have a 42mm chainline so you should find cranks and bb that will achieve the chainline your hub requires.
the back wheel will have to be centered as there is a large aero thingo which pretty much sits right on the back wheel.
if it was offset 5mm it will rub
You might want to read the post again. I made the same comment earlier on, however it will make a difference if the spacers aren’t the same on both sides.
Yeah, uneven spacing would require redishing the wheel… Anyway, that’s only if, in the unlikely event, it doesn’t work with a 108 anyway.
Make sure you post a pic when it’s done. The raw carbon looks great, I wouldn’t paint it; but if you are going to paint it, shortsie is right, matte black would be sweet.
OK I read it again and I still disagree.
I believe the hub’s intended chainline should drive the choice of cranks/bb, not the other way around.
He’s already got a track hub, which will have a 42mm chainline. Spacing the hub to 130mm doesn’t change the chainline (assuming of course that it is spaced equally on both sides. I don’t why you would choose to space it asymmetrically anyway).
So if he’s already got the hub, there’s no advantage in getting cranks and bb and then trying to change the chainline at the hub to match the cranks.
Maybe I’m missing something?
WILL BE SPACED EVENLY
the one i have coming is mostly white with raw HM carbon.
happy to post pics when i actually get the thing.
was thinking of putting proper track forks in it but i think the clearance between the frame and the wheel will be touch and go (or maybe stop)
at the end of the day im not the greatest bike rider so it doesnt really matter. seems to be a nice cheap way to get on a decent track bike though.
can any one recommend where to get a 107/108 BB in AU?
Agree with snowflake, why space asymmetrically and redish? 42mm is the ‘track’ standard, stick with it.
But; What is the hub? Is there enough axle length to add 10mm of spacers? You may need a new axle. My IRO (Formula) hubs have extra long axles and can be spaced from 120 to 135mm, but this isn’t always the case.
You don’t have cranks yet do you? So don’t go searching for a 109mm BB until you know you need one.
An FSA track crankset would suit the look of that frame.
I agree, it’s highly likely that the set up will be fine. I was just covering all bases in case, for some reason, the carbon frame has insufficient clearance with a standard track BB and his chosen crankset.
Case in point… FSA carbon track cranks have poor clearance and required an extra BB spacer on a steel frame to prevent contact.
Yes, the better approach is to match the crank/bb to the rear chainline.
i reckon the sprocket to frame will be tight.
can any one suggest a crank/BB supplier? ebay? are the pake’s ok?
pretty sure the hubs are suzue. will check when my wheelset comes back from my mate whos been borrowing them for the last track season.
if the axles too short i will just relace a forumula fixed/fixed in there and ebay the old hub off.
I’ve got a set of new Origin8 cranks and BB which have been relocated to for sale section
So that’s why you want him to match his hub to your cranks/BB? :wink:
Hahahahaha, it would be hard to argue my way out of that one.
