Yes yes. Nipple lube.
What brand/type do people use for wheel builds?
Is standard bike grease ok. Or should I use some type of oil? Also been told to use loctite?
Opinions?
Cheers
Opinions?
Cheers
Don’t use grease. Or loctite.
Some old school builders use a very light coating of very light oil on the spoke threads.
Me, I use automotive anti-sieze (a copper-based paste) on the spoke threads - lubes the spokes on the way in and prevents seizing later. There is a similar product specially for spoke threads called “spoke prep”, which is similar to what I use. The auot anti-sieze is much much cheaper.
old school = light oil
Another Olde Tymey tip: Dip spoke threads in boiled linseed oil.
Lubes upon building, dries out and acts as a light thread lock after.
I did this for my first set of wheels. They’re still round FWIW.
Read others talking about linseed oil. I’m going to go that way.
Thanks for the ideas.
7 bucks for half a litre. Reackon I’ll use about 10mils!! At least it’s cheap.
Picked up a 3 mm syringe at the chemist for application.
Or you could just stick the spokes in the tin.
and you can put it on your breakfast cereal to get your daily omega-3s…
I use a loctite medium strength stick on the threads and a pen oiler on the nipple/spoke hole.
E
jeeze dude, it took a week of this thread and this is the best you could do? you’re slipping CraigC(no pun intended).
Fuck you Veg boy. I get stuck out at mine sites in PNG and you cunts are all being nice to each other ‘n’ shit and giving practical advice. ![]()
Gimme your cracked pompino frame NOW
On that sort of nicker you can give me $100 for it.
i used olive oil for the hell of it… it actually stunk after a while. i regretted it. i’m going to use linseed next. thanks for starting this thread!
What do you want with a cracked pompino frame CC?
He wants to take it home and fuck it.
Magical juice I wish i had an everlasting fountain
http://www.triflowlubricants.com/Superior_Drip/superior_drip.html
My two cents lube with wet lube like finish line just the spoke ends then use Dt spoke freeze at the end of the build it’s a kind of light loctite that can cut through the lube to lock the spoke in place but can be moved again with a spoke key. But it can be hard to move the nipples again if no lube has be used. It is good to use on jump bikes and mtb’s when a bad flat landing can de-tension a wheel really quickly.
