This build started out with a Master Sports frame bought for about $12
Alot of surface rust and what was left of the original paint and decals was removed with a steel wool drill bit (attached to a drill), some sandpaper and alot of elbow grease. Rattle can paint job followed, leaving the lugs and fork crown exposed and clear coated.
I had the original intention of building a beater but I ended up giving all my scrappy parts and wheelset to a friend for his first conversion. A few months passed and I ended up fitting it out with some nicer components. It’s a tad small for me and a longer seat post will probably make things a little more comfortable. Apart from that it’s already had three rides out in some very wet Adelaide weather and performed quite well. Cheers to Kym at North Adelaide Cycles for his help
58cm Master Sports road frame
Velocity Chukkers to Origin hubs
Sugino RD-2 Messenger crankset 46t, and BB
Old Crank Bros eggbeater pedals
San Marco Rolls saddle
Sakae FX seatpost (soon to be swapped out)
Hatta Swan njs headset
Nitto Jaguar Pro njs stem 120mm
Nitto RB-021 pursuit bars
Izumi V njs chain
Dura ace njs 15t cog and DA njs lockring
