Had a small run in with the back of a car the pulled out in front of me two days ago. Doesn’t appear to be any damage to the bike, and just a little sore shoulder for myself.
Looking at it now, I think my forks might be bent back ever so slightly.
What do you guys think? And if so, does it matter? It’s just my beater…
Maybe slightly bent? It’s kind of hard to tell. I’ve known plenty of people to run slightly bent forks on their beaters with no issues. try riding no hands to see how the steering feels.
For steel forks only slightly bent it should just be a question of handling above the danger of failing, especially for a pub beater. Riding no hands is one thing, but also see how it performs under braking (if you run a front brake). When I bent my forks the bike pulled hard in one direction when I braked hard … completely reduced my confidence riding in traffic.
I just replaced some cr-mo canti forks that looked similar…are they/ aren’t they kinda deal??? straight edge said it’s time to go. My replacements were from the scrap heap at LBS though. Didn’t see too many round bladed tarck forks in the dumpster though.
Where is it bent? It’s not the fork legs, and it’s unusual for the crown to bend (but it can happen whether pressed steel or investment cast) so i’d say the bend is at the fork crown/steerer junction. Most steerer’s are butted at that area but if it’s compromised and you haven’t taken it out of the frame to inspect if it’s cracked or likely to fail then I hope you have dental insurance.
Within limits you can bend steel and it’s no issue, but if the brazed joint that holds the steerer to the fork crown is compromised then that’s not a good thing. Open it up and see.
Compulsory third party (CTP) insurance is Australia wide AFAIK. It’s just that in Victoria, it is included in the registration fee. CTP covers person, not property.
As for the fork. It doesn’t look too bad, but heed spirito’s advice, padawan.
I think you are being overly pessimistic about the characteristics of steel forks. How do you think fork blades get a bend in them and how does a framebuilder do the final alignment of a new fork? Bent cold and nobody worries about the possibilities of the blades breaking.
Check that the steerer isn’t bent and cold-set the blades back into alignment if they are bent.
