but they are hard to get onto my risers, the risers may be to thick but the grips seem to go halfway on then it is to hard to push them on any further, someone said use an air compressor to get them on, how the hell would you do that?
its like putting a grip on a cricket bat.
any tips on putting grips on?
lubricate maybe?
Deoderant should work as well. Anything in an aerosol with a high alcohol content, so that it evaporates quickly and they stick down.
The ultimate workshop method is to spray a bit of isopropyl alcohol in the grip, whack it on, then push the nozzle of an air compressor just under the grip and give it a blast to dry out the iso. Bam, instant solid grip.
The best method i’ve found is placing 4 cable ties up the inside of the grip before its mounted, then slide the grips up the bars relying on the lower friction of the plastic on the bars rather than rubber grip. If that makes sense?
Its the only way i can fit my champ grips onto my risers.
tried the hairspray method before that but it never dried in 4 days. still wet as! so i used a method similar to the cable tie one mentioned above. cut up strips of a display folder plastic cover instead and pulled them out with pliers once the grip was on.
