Looks like I’ll need to replace some soon. Its a 5750 compact, double.
Should I go with Shimano or are there others around which will do the job as well, or better?
Thanks in advance!
Thanks in advance!
Stronglight 7075 rings are well priced and last for a very long time.
Search the euro sites like xxcycle / bike24 / etc for them. Be sure not to get the Campy 110 ones, they have a different drilling.
I bought an Ultegra 6700 ring (inner 39T) from Bike24 and it was like only $15 (ex shipping).
Thanks Blakey. I did see the Stronglight ones on Ribble, but they didn’t go down to 34. Will have another look around.
Also, any recommendations on quality replacement cables would be appreciated too.
*search function has been utilised btw.
Yokozuna reaction, or genuine shimano (SP41).
These are the only shimano compact rings on ribble
Stronglight Dural 5083 110mm Shim 9/10 Chainring, CHAINRINGS
Make sure you get something with 110bcd, you must have been looking at the 130bcd if they didnt go down to 34t!
This is why I suggested XXCycle etc., not just ribble/crc/wiggle.
Duh! Yes… I’ll have a better look at home without the work distractions. Thanks guys.
+1, bit stiff to work with, but once cut to length (used a dremel for brake outters) and set, its just smooth.
Have got Yokozuna cables - are sick
Check out Praxis chain rings - have got, are sick
I’ve got some lightly used 105 34T/52T rings you can have. I’ve had them valued at a coffee and croissant. Txt me.
