Roadie Frame advice
Gday fellas,
I know this is a fixie forum, but I thought I would try to see if any one could answer my question.
Looking to purchase a Cinelli Xperience 2010 frame from slane cycles (Cinelli Xperience White/Black Module 2010 [A85] -) but not sure of what size I should be looking at - L or M?
I currently ride a 56cm Fuji Track Comp and I have been comparing the two geometries in an attempt to determine my correct sizing…
Anyway - I am a 85kg, 182cm tall and have an inseam of roughly 75cm.
Any advice on the L or the M frame?
Geometries view - Cinelli Xperience geometry
Fuji Bikes - Track Comp - Fuji Track Comp geometry.
If you had a spare 10 minutes, you could try the Competitive Cyclist fit calculator. It usually tells you to go on the side of a smaller frame size and run a longer stem. Quite detailed:
Fit Calculator - Competitive Cyclist
Those compact frames can be quite confusing for sizing. What stem length do you have on the 56cm Fuji?
  1. go to a bike store.
  2. ask to be fitted.
or
  1. go to a bike fit professional
there are so many factors involved in bike fit. a bunch of schmucks on some forum ain’t going to be able to do it for you.
