saddle plane is one of the most common things that people don’t get right. internet pics also help make saddles appear out of plane.
now, what i’m after is a concensus for measurement…how should one measure to make sure your saddle is “level”
put a ruler/plank of wood/hardcover book on top so that the two highest points are parrallel?
ignore the rise at the rear of the saddle, and just measure from the sit point to the highest point along the nose?
given there are many different shapes for tails and noses, can a general rule (with only a few exceptions) be generated??
It depends on bike fit, body shape, saddle and more.
But I run just out of level nose down.
This helps put my hips in a better spot and takes the weight of my gooch.
Depends on the saddle you’re using but trying to level it by tip and tail doesn’t work on a lot of the time as many are not flat. If you make sure the middle section of the saddle is level you are usually heading in the right direction as far as comfort is concerned. It can look a little nose down sometimes so it might not be aesthetically pleasing to everyone.
