Is it possible to get the Shimano R685 hydro brakeset as part of a groupset? Or is it only available as a seperate purchase and onsell the other brakeset from a groupset to recoup some costs?
Had a squiz at Ribble and a few other places and looks like its a no, but maybe someone knows something I don’t.
tentatively… you can only get the r685 as OEM, we had one fuck out at work a couple of weeks ago and we switched both out for uniformity, pretty sure shimano aus don’t have it for sale, think we used rs685 as replacements? ps road hydro levers and mtb hydro calipers wont always play nice together, we hooked up a different mtb caliper and the lever feel was pretty whack. carry on
Geoff: get an xt rear hub and get it machined for 11sp. I’m doing that, found a local guy who does it.
I bought the components individually cos it was only slightly more expensive than parting out the rest of the group and saved hassle etc. But might be worth it…
Hope Pro Evo II 40t is 11spd road compatible. Only thing is you need to buy the 11spd cassette body as well… cheaper than WI and probably what I’ll be doing.
that was my complaint about the cx75, I have a slightly used set of Open Pros in great condition and would like to build them up but figure if I do I want the option of using them on a disk frame.
Does anybody else know of a road hub set with 32 holes and 11sp compatible?
Went looking for Silver CLD 32H rear availability in AUS, not so great, but can be got from the States for about $429 delivered.
Paired to either a Silver Archetype (Wonder if H+ will do a disc rim eventually?) or a Polished Velocity A23 looks to be two options. I’m sure there are others.
Pacenti or Stans are two options. Neither do silver or polished.
I should really start another thread for the dream Wolverine build, as it’s original build will be whatever I can swap over from the Dambala to get it on the road, so flat bar,single speed, cable disc is up for starters.
