South Aus Pub bike frame
As per title, Ricardo Tange Champion frame, fender eyelets, 56cm
ricardo elite steel frame 56 cm, Tange champione tubing. | eBay
Hmmm. I have everything to build that up except for two brake levers, but no need for it. Would be rad with a front rack though and risers for a commuter though.
Do I bid?
27" or 700C? Hard to tell.
Guessing it’s 27" as the same seller has the ‘other bits’ for this.
Yeah, I saw that and talked myself out of it.
I have two levers you can have.
This is actually perfect for a mate of mine. Have you got room in your car for 2 frames JLN? I’ll buy you 1 more beer than Rolly does
It’s only a lowly #5 PG tubeset, starting bid would be max$$$
So it is, for some reason I thought it was #3. I’m out
And have confirmation from the seller that it is a 27" frameset.
