Tips for Happy Riding
[ul]Learn right away that the front brake is the most effective one, and to never lock the front wheel in dirt (or on the road, but it’s more likely in dirt). Learn how far you can lean over without scraping a pedal.[/ul]
[ul]Learn to keep the inside pedal UP when you corner, and learn to ride safely in all conditions. Be the master and commander of your own bicycle.[/ul]
[ul]Signal your approach to pedestrians, especially if they’re old, and a bell is better than “On your left!” If no bell, try clacking your brake levers. If all you got is “On your left!” that’s fine, but if you ride a lot on paths, get a bell.[/ul]
[ul]At least one ride in 10, go without your sunglasses and gloves. Sometime next month, put some double-sided cheap-style pedals on a good bike and ride in non-cycling garb. It works shockingly well, and sends a good message to would-be bicycle riders.[/ul]
[ul]Carry an extra tube you can give to somebody with a flat tire and just a repair kit.[/ul]
[ul]If you’re a guy, don’t try to be a mentor to every female cyclist you meet.[/ul]
[ul]Don’t ride in shoes you can’t walk through an antique shop in.[/ul]
[ul]Don’t wear clothing that makes your sweat stink even more.[/ul]
[ul]Don’t think you’ll go faster in a significant way if you and your bike become more aerodynamic.[/ul]
[ul]Put a $20 bill inside your seat post or handlebar and hold it there, somehow.[/ul]
[ul]Don’t ride until you’re confident you can fix a flat.[/ul]
[ul]If you ride more than one bike, have a set of bring-along tools for each one. Learn how to remove your rear wheel (put the chain onto the small cog, etc.).[/ul]
[ul]If you ride in a group, bring food for you and somebody who forgot to.[/ul]
[ul]Go for a one-hour ride underdressed sometime, because it’s good to be really cold on a bike every now and then.The reverse (overdressing in hot weather) is not necessary![/ul]
[ul]Never blame your bike or your health or anything else if you’re the last one up the hill or in to the rest stop.[/ul]
[ul]If your brake hoods are black, wrap your bars with a different color tape, so it doesn’t look like a one-piece set-up.[/ul]
[ul]Never let your chain squeak.[/ul]
[ul]If you pass another rider going up a hill, say more than “Hi,” but if it’s a woman and you aren’t, don’t assume she wants to chit-chat. Treat her as you’d have a generic guy-rider treat your wife/daughter/girlfriend.[/ul]
[ul]If you’re a woman and it’s a guy, you can chit-chat all you like, they won’t mind.[/ul]
[ul]If you see another rider approaching you from the rear and trying to catch you, let it happen. Fun is more important than fast.[/ul]
[ul]Don’t put any cyclist up on a pedestal, except Lon and Freddie.[/ul]
[ul]Sometimes, bring normal food on your ride. Sometimes bring none. If you’re reasonably well-rested and have eaten anything at all in the last eighteen hours (and are not diabetic), you should be able to pedal your bike for two to three hours without supercharging your system with carbohydrates. Believe it or not, carbs really do make you fat, and are necessary only for long, hard rides.[/ul]
[ul]Shoot photos on your rides and give them away.[/ul]
[list]Feel comfortable mixing high tech and low tech, old and new parts and%2
