hey:)
im starting a new project bike and i have a few questions i thought i would ask you:)
i like the look of the visp and leader frames but they are either over my budget ($200) or the quality and reviews are not entirley reassuring… i have stumbled across this on cycling deal. what are your thoughts? and has anyone had any previous experiences?
i also noticed the stem post is quite large… does that mean i will have to get a large amount of spacers or can this length be shortned? sorry bout the novice type questions
The fork you can just cut off above your stem height,
it just comes like this so you can choose how many spacers or how high you want it.
If your budget is about $200 then this is all your going to get or an old road bike for a conversion,
Quality isnt the best but it isnt going to fall apart any time soon,
just get it have fun with it and if you like it still in a year just upgrade it.
You should search up “VISP” in the top section and PM people that have VISP frames to get their opinion. Usually the stem post (im not sure if thats the correct name) can be shortened but i’m not sure. I’ll leave that question for someone else. EDIT - Pressed post button before I knew Dayne posted.
What is your total budget for this bike build? Work out that, then look for frame and parts. The VISP frames are good for the price. All else fails have a look at cell bikes, they are doing some good deals atm.
Its basically the same frame… Much like the visp and fuji track pro or leader are the same frame. They look the same, just have subtle differences. On this frame the only difference I’ve seen is the rear spacing, which is 115mm not 120mm.
I have a visp and im 100% sure that is a repainted visp.
I reckon they are great beginner frames really tough and stiff. for the price you pay i reckon its worth it if this is your first fixed gear.
Fork ends (rear) are a different style, it has cage mounts on DT, and rear spacing is different.
How is that a repainted Visp?
I’ve had a Visp in the past,and this frame, whilst similar, is NOT the same!
