Frame - Vivalo Special NJS - Reynolds 853 with 753 fork (thanks 2Joes2)
Wheelset - 36H NJS Suntour Superbe Pro hubs to H+Son TB14’s (Built by Sam at Treadly in Adelaide - big ups!)
Tyres - Vittoria Open Corsa Evo
Headset - Hatta
Bottom bracket - Sugino75
Crankset - Suntour Superbe Pro
Chainring - Fyxomatosis
Pedals - Suntour Superbe Pro track w Toshi Doubles
Chain - DID stainless
Sprocket - Suntour + Suntour lockring
Saddle - Kashimax Aero Custom - Black Ostrich
Seatpost - Nitto
Stem - Nitto NJ Pro AA
Bars - Nitto B123AA with Newbaum’s cloth
Solid build. Not taken anything away from the build, but woulda preferred a Pearl stem on this. NJ Pro + B123’s making sitting in the drops more a chore then anything. None the less, great build!
I was going to say the same i could only run a pearl on drops.
I only run the pro on risers i just don’t feel stable that dropped plus i have a dodgy neck.
But hey still class.
Nice work, look forward to seeing this around! (Assuming you live in Adelaide)
To echo gyp and dayne’s stemtiments (see what I did there?) - I ride with a technomic stem on my keirin frame, you will likely do the same in the future if you ever want to feel your drops again. Do you know a good chiro?
That said, I ride the tecno on the street but the nj pro ALWAYS goes on for photos!
As I am obviously not as rad as JLN, I suspect the drops may be sidelined soon enough for some rizors. And then put back on, and then taken off, and then…
