I’m sure you all know “a friend” with this problem: Too many bikes in the garage.
In my case there are six bikes. 1 is on the wall. 1 can lean against the wall.
This leaves 4 bikes that need a place to live and i can not drill holes in the wall. Solution needs to be cheap and reasonably strong. There is floor space available but not ridiculous amounts. Please discuss.
I’ve got a similar situation (albeit only with 4 bikes) but I’m renting and also can’t drill into the walls. Plus all my bike are in my bedroom in my stupidly small unit. At the moment, I’m leaning towards this solution. I can have two bikes on the rack and then the other two on these stands. Might be some things to consider.
basically cut the rear triangle off 3 (or more)old bikes and thread onto a piece of box steel from bunnings (~$20). You can drill and tap a 6mm hole in the BB to use a grub screw/6mm allen bolt to hold them in place. Then cable tie old tyres on the seat/chain stays to stop scratching.
This is right by the front door at my place. Its on an old rug so don’t have to worry about dirt and stuff. 3 of us use our bikes everyday so its works well.
I don’t have rafters so no easy ceiling mounts. El Brado’s rack option looks good, and no drilling required. One of these is an option: 50 dollar floor rack for 4 bikes but takes up a lot of space.
Maybe i will just wing it and drill a few holes in the wall. Put a decent piece of wood up and mount a few of those hooks. Little floor space required.
I meant more that when you place the front wheel on these hooks, there is a tendency for the hook to push upwards on one of the spokes, rather than just the rim.
Nope. But if i leave and take the bolts out, stick a bit of putty in the holes, no one will ever know. The garage wall is red brick with white paint peeling off everywhere.
