Been riding my new fixed build up. Currently ride 46/16t 170mm crank for my communte to work. What is a good rear cog size to use with my current 46 and 170mm crank arms to practice a few tricks? I don’t want to change cranks as they are Pauls and look a bit flash.
i guess generally for tricks, the lower your gearing the better as you will have most control over the rear wheel. for a 46t front, maybe give a 20t cog a shot.
Well i’ve changed and swapped my chainrings and cogs, and i’ve found that the more skid patches you have the easier it is to skid quick, and at high speed.
yep just smaller gearing, that’s the important factor, and allows you to put more torque to the ground (though you will have less top end speed).
all the number of skid patches tells you is the number of different positions your back wheel can be in whenever your cranks are in a certain position. and therefore the number of skid patches on your tyre, assuming you always skid with your cranks in the same position. its determined by your gear ratio: http://www.sheldonbrown.com/fixed.html#skid
in black (have a mate that deals with the…lucky me) so would you suggest a 19t ot he rear? I ride MTB and road bikes (sorry bout that!) and can do okay wheelies etc on the MTB. Do u think this will be ok for doing some fun stuff on my fixie?
