Scored this off Freecycle today. Just wondered if this type of frame is for a particular kind of riding? Its 531 tubing, straight forks, tight rear end with recess in seat tube for wheel. Also has a longer seat tube that extends above the top tube. I haven’t counted the teeth but the gearing also looks to go pretty low.
One other thing is this crack in the paint? at the lug. Is it likely to just be in the paint and therefore no problem? I took the seat post out and the seat tube looks like it is one piece that goes directly through the lug, I cannot see a crack from the inside.
At this moment in time I’m thinking of making it a commuter with rizorz.
Just scraped the paint off, can’t decide if it’s a crack or a deep scratch. Has the same thing going on the other side of the lug but not as bad, so I think it might be screwed. Will be stripping for groupset shortly!
