I’ve only ever laced 36 hole rims and hubs before using a 3 cross pattern.
Today I’m attempting a 40 spoke, 4 cross pattern.
My question is after my first ‘lead’ spoke do I use every 4th spoke hole on the rim as I would in a 36 spoke rim?
Hope that’s clear enough.
yes. Just follow the steps exactly the same way as you would with a 36 hole wheel.
Thanks Sir Kev
Are you planning on carting elephants?
Why 40 spokes?
That’s how many holes there are in the hub.
HUB track hub Airlite 40 hole (eBay item 190448080818 end time Sep-30-10 20:52:36 EST)
These hubs are brilliant. When you do a 3 cross 32 spoke lace on the front hub and a 4 cross 40 spoke lace on the rear you can use the same length spoke (providing the ERD of the rims are the same).
Very clever when cyclists/mechanics didn’t have 100 different spoke length to choose from.
That is a obvious answer to a obvious question.
Thank you.
