Does anyone know who distributes a 6 speed internal hub with 120mm spacing at all?
Contemplating setting up the steamroller to have some gears.
Thanks in advance
Cam
Thanks in advance
Cam
2, 3, 5, 7, 8, 9, 11 & 14 I’ve seen or know about. Did not know SRAM makes a 12 speed one. Does anyone even make a 6 speed internal hub, let alone distribute it? Closest would be one of the new Pinion options, but again, not hub, just mid mount gearbox.
maybe it wasnt the 6 speed then, someone mentioned you could get a 6 speed one. cheers for the above info.
Hey cam, the one i was mentioned remembering the other week was the Six Fyx, which is 6 speed derailleur
Yeah, this one: IB13: Fyxation un-fixes your fixed with 6 speeds with SixFyx, Plus new Leather Goods - Bikerumor
Was discussed back in 2013: http://www.fixed.org.au/forums/showthread.php?t=29237
Edit: here- Six Fyx Conversion Kit - Complete Wheel – Fyxation
Ah yeah that’s the one, couldn’t remember if it was internal hub or not.
Cheers!
if i can add my somewhat irrelevant 2c, internal hubs are actually a bit lame. ruin really nice SS frames.
(I have a 11sp di2 alfine on my pompetamine and while the fact it goes pew pew is awesome, the bike is now a bit of a pig because of it. works well, but a heavy, heavy pig)
