Criticise me if you will, but I want to run two, finger style, brake levers on my Nitto B125AA track bars. I bought some Tektro RL276’s off Velogear and the clamp on them is a bit too big for the bars, which have a 25.4 clamp size but the actual bar is a wee bit thinner.
The Tektro’s don’t even come close to gripping, does anybody know of any brakes that are likely to fit? Or if not what is the best way to make a shim for these ones?
if you go for the diatech levers, i’m pretty sure it’s only the silver ones that come with the shims, all the other colours are to suit bmx bars (22.2mm??)
Thanks for your help everyone, I’ve ended up ordering a pair of smaller Tektro’s, the RL720 has a smaller clamp than the 726’s and are slightly smaller as well, they should look good. I might try making a shim anyway just to know I can.
