For those who are framebuilders and repairers
I have a steel mtb frame here I would like to run discs on eventually. I wanna throw a set of paragon rear dropouts onto it (with the disc tabs already on them). Partly to get vertical dropouts as well. It will require shortening either the seat stay a little for a top mount tab, or the bottom one for a low mount tab but thats fine.
As a guy who can weld with electricity, and have done soldering at school using a gas oven, how likely am I to be able to braze em in myself?
Dad can braze and has an oxy set so I can get him to show me the basics, and go from there. Seems like a fairly straight forward process… main concern being alignment but measuring and checking thrice and brazing once should get me there right?
And for the fork, I will use a long tang disc tab, but how the hell do I line it up properly? Will probably add a bit of bracing to both legs for safety
