Campag 11 speed, though you’d probably need a campag triple front mech and a triple shifter to work well which is expensive. I’d double-ify it (46-30 maybe) and use Athena 11speed, and you’ll maybe need a new basic (veloce) front mech.
This is what al9000, Erle, iamsimon?, me and some others I know run with variations its good.
Yeah Campy 11sp shifters will be the best. I’m actually running mine with an xt front mech and it’s pretty good. Was a little fiddly to dial in but has held up ok. Reckon I might try a cheap campy mech to see the difference sometime but if you’re tight on cash grab the ergo shifters now Jimmy and you should be fine with your current front mech for the time being.
Got mine off wiggle for a decent price just make sure you grab the triple version
i figure there’s a better chance someone there will have DA/Ult/105 9sp at the swap…i assume that i’d buy the wrong thing somehow regardless. but will see what happens.
maybe i’ll get a couple of bottle cages…can’t fuck that up.
