Does anyone know what the size of the flanges and center-left flange and center-right flange measurements are for the campagnolo pista record rear hub is? also measurements for front hub as well would be great.
cheers
cheers
For new model hubs, go to this page and click on the “RECORD PISTA hubs instruction sheet - 02/07” pdf on the lower right.
I don’t have measurements for old model Record. I do have the 120mm Nuovo Record high and low flange ones and I’m PRETTY sure they’re the same as 120mm Record but I’m not entirely sure that the hubs are identical. Someone would have to chime in.
http://www.sheldonbrown.com/rinard/spocalc.xls
should have everything you need, ive had wheels built based on the hub measurements in this link without probs (same hub as you)
