Hey all, as the title states, can I use brakes if I change my wheels over to deep V’s?
I had a look at the velocity B43 and it says it has no braking surface… does that mean I cant use brakes with them? or I can but it just wont stop like it should? any suggestions for a cheapish V rim? thanks
You can use brakes on a rim with no machined braking surface, but obviously they won’t perform as well.
Be aware some of the B43 and Deep V rims are powder coated- this makes braking really poor until you wear through to the metal.
You can get machined sidewalls for Deep V
You can use brakes with both machined (designed for a brake) and non-machined (not designed for a brake). Machined rims will stop much better than non machined, usually because the latter are painted, rather than prepared metal.
So either way you will be fine, but braking will be much better with a machined side wall. A good bet is just a simple Velocity deep V, Mavic Open Pro, or similar.
Cool beans. This site has been so helpful so far. lol
I read somewhere that I can semi sand down the clear from the edges so the brakes work better? any truth in that? I saw someone with a B43 that appears to have a machined sidewall for the brakes. Might ask him about it!
I imagine the brake pad has just ‘machined’ through the paint.
Best thing to do is ride in the wet- the grit from the road will get between the brake pad and rim and you’ll be down to the metal in no time. Just be careful at the start though because the powdercoat has a tendency to ‘grab’ when you brake.
My opinion is to get the Deep V over the B43. B43 doesn’t have much going for it.
I used to ride a b43 with non machined brake wall. It was useless in the wet, in the dry it was fine, but the wet it just didn’t stop. And it was well worn through the paint.
Looking at that I will probably just get the Deep V. I can get it with machined sidewalls. lol
How much do deep v’s usually go for? on king of the mountain cyclery they’re 200++ but its the gold anodized ones. I just want white or orange ones lol
Thanks guys. Super helpful. Gonna check out some I saw online tmrw and see how I go. Atleast the basic info I need is there. if its powdercoated It’ll suck until its worn through and deep V’s will be better than the B43.
Anodised will be fine with brakes.
Powdercoated is highly not reccommended, especially if they were wet.
You sand a sidewall yourself, you void the warranty.
Deep V’s Non Machined is fine.
B43’s will work, but have a tapered sidewall, so pad adjustment is required.
