carbon poast/alu frame...
do i use grease or carbon paste or sometrhing else?
thans - yours in christ,
mckenny
Carbon paste.
Go to your LBS and see if they have some in little sachet. A lot of carbon bikes come with it for assembly and it never gets used.
carbon assembly paste best, grease can be used but might compromise the clearcoat on the seatpost. If you install it dry you’ll need to whip 'er out and inspect and reinstall every couple of months WITHOUT FAIL to guard against galvanic corrosion.
thanks all!
