I have found that recently my chain has been skipping quite frequently when i skid/accelerate at the lights/ride out of the saddle and it scares the shit out of me. I’m running a 46/16 and my chain is not excessively dirty nor is it loose. I’m not particularly knowledgeable when it comes to this stuff so i was wondering if the more experienced people here would have a better idea of the cause of the issue.
+1, lockring/cog came off my hub once while whipping down a hill…was quite amusing, stripped the threads. Had to use the freewheel brakeless, the shoes didnt last long
Stephen, take your bike into a shop and get them to do up the cog/lockring. They’ll have a proper lockring wrench that will be able to do this up properly (tight enough). It’s one of those jobs that you wanna be careful doing yourself, a) because you really need to use a track chainwhip and lockring wrench (there are two sizes: Japanese and Italian); and b) cause if you slip it is possible to cut your hand or arm quite badly on the cog’s exposed teeth.
Do it soon as you’ll screw the thread on the hub pretty quickly if you don’t.
if biking is something more than just transport buy the tools you need and if you have an lbs that you frequent ask them to show you how to do it. best advice i was given once i was bitten…
So, 1 monthish later
I had my lock ring tightened and everything and all was going well, I was riding up a hill one night and i felt it come undone again. I kept riding because i thought that it would at least be okay until i got home. NOPE, the lock ring and cog came off when i was riding down a hill. I’m pretty sure that the threads on my hub are fvcked because no matter how much i tighten the lock ring (even tried using a new one), it comes undone ridiculously easily. They also look pretty shredded
Do I just buy a new hub/rear wheel and use a better lock ring (that is tightened properly)? Current wheels are the alexrims that came stock on my fuji classic.
Now that you’ve trashed the stock wheels you invest in a good wheelset. Kinda a rite of passage I reckon.
Handbuilt wheels - quality high flange hubs with sealed Bearings - 36H rear, 28H front x double-butted spokes (radial front, 3 cross rear) x Aerohead or Deep Vs FTW
(All you Deep V haters can suck it).
And by the sounds of things you should invest in a fixed/fixed hub…
