Gudday
My friend brought her bike over, saying that the chain was slipping in all gears. Not surprising; it was absolutely knackered, every cog and chainring. I’ve replaced the cassette and I have a Deore M590 crankset to fit, but I’m having chainline issues.
I measure the chainline of the cassette at 38mm, which is a bit weird. There are no spacers on the RHD to swap to the left to redish, so that’s out. The Deore M590 has a chainline of 47.5mm if centred. I can put two spacers on the LHS and get a 45mm chainline, but the left pedal ends up being 5-8mm further out than the right pedal. She wants the same gearing that she had, which was 28/38/48. I didn’t measure the original chainline, but maybe I should have. I imagine it must’ve been 45mm though, which might account for it being so warn out.
Anyway:
In your opinion, how big of a deal is not having the crank centred, as in, having the left pedal further out than the right, using platform pedals?
How big of a deal is running a 45mm crankset chainline with a 38mm rear? I imagine it’s less than ideal. Worse if I centre the crankset with a 47.5mm chainline.
My options are:
Trying it out with what I’ve got
Getting something like a Tiagra triple, but it’s 30/40/50, 10sp, and still a 45mm chainline, or 42.5mm if I space it out to the left
Sourcing a square taper triple and getting it as far in as possible according to the BB axle length. This would probably require me changing the chainrings, adding to the cost.
Convincing her to go compact double, but she’d like a low gear for touring.
The FD is not an issue. It has plenty of room to move in and out.
