Hi guys, was wondering, if i have a oldish set of velocity deep v’s that have been used on a roady, is it worth changing the hub on the rear wheel and should i simply buy and new rear?
cheers
cheers
If you can get a rear hub for a good price that has the same spoke radius it’d probably be a good idea. Otherwise it’s another $40 for spokes. I’d probably give it a go. Cheaper than a whole wheel.
Depends on how worn the rim is I guess?
+1
Look for a hub first.
Surly Fixxer?
ok cheers thanks for the help
