frame: eighth-inch scrambler v2 57cm
wheelset:
F velocity b43 laced to origin track hubs w/ 28c gatorskins
R velocity b43 laced to flip flop origin w/ 28c rando
drive train: lasco 170mm cranks and 44t chain ring
dura ace 16t track cog and dura ace lock
seat some old thing had lying around.
stock headset with the frame and same with seat post.
lasco’s seem to be holding up really well so far
Also i was reading in the gear ratio and apparently 16 tooth arnt a good ratio with 44 cause of skid patches?. any help with that cause i skid alot.
cheers
Nice build… good to see another one of these built up…
not so sure about your stem though… looks a lil “mountain bikey”…
i run a 60mm 6deg down-angle stem on mine(same 57cm v2) & it gives a really nice look. I tried about 6 variations of stem lengths & angles before I found what looked/felt best … but each to their own.
thanks for that was playing around on that site and if i got up too 19t, i would get 19 skid patches is it worth it ? im going to go get one tomorrow if so
thanks heaps.
