Here’s a frame you’ll make no money from, will waste 10 minutes of your time and I’m not paying for your expertise or years of knowledge yet if you don;t answer likely I’ll think you’re rude or worse, and I’m expecting you to be a miracle frame whisperer.
put things like “quick enquiry” on your website, expect people to use them, maybe you should all let joe cosgrove decide what is and isn’t a waste of his time
On a side note i spoke to Joe today again about some work hes doing on a frame for me.
The Guy is such a legend.
My frame was most likely built at Zillmere in Brisbane when he was working for Robert Johnson and building frames under the name Rapallo.
Joe worked with Brett Richardson and Robert before moving on to do his own thing
You can see the Rapallo decal on his tool box in the photo’s above.
Im taking the frame out to him later this week along with another one to have some work done on.
Hopefully the website will generate some good buisnes for him and may be even some more frames to build.
