I believe the strength argument - though properly installed chains rarely break whether 1/8" or 3/32" so it’s not really an issue. 1/8" setup has a longer wear life which is relevant for SSs.
In the past I’ve done the same thing 50/19 on the street turning the wheel around to 50/14 for the track - and yes, I needed to add links. Using 2 springclips meant changing the gearing by about 25 GI was only a couple of minute job.
put it up to 47 x 17 a while ago, and it’s stayed, mostly because i’m lazy though. a bit slower off the mark but i reckon i do about 150km/h down wilson st.*
45X17 with a 25mm tyre
30 something skid patches if you skid with both legs.
Works for me. Lots of hills, no brakes, good on flat and you can stop coming down hills!
I used to run 46 x 17 but changed to 46 x 18 a while back for rides with the girlfriend and it stuck on me. Spinning down small hills is sweet and it’s only really bigger ones such as the Col de Studley where it I spin out and end up using the brake.
