I need some help removing a headset. I can’t get the threaded top race off :?(pic below)
Its not a normal setup or at least one I have seen before… there are no flats for a spanner. It has a grippy ring thing. Is there a special tool I should be using.
Screwdrivers are good but sometimes do damage. I have found using an old screw that has had the tip broken off then ground down a flat end very good for removing headset cups.
best trick ive recently got onto is using a bit of tubing from an old vacuum cleaner pipe from hard rubbish. it’s just a bit smaller in diameter than the head tube and with constant fast hammer tapping for a few seconds knocks out the cups no worries, you get a nice even distribution of the force around it so it doesnt chip bits.
Similar to the vacuum cleaner pipe method,I hacksawed a slot down a piece of tube then you can spring it open a bit and it gives you a bit more contact area on the cup you are trying to remove.
Yeah, I printed some out at home about six years ago, When you clear coat them,you just have to put light coats of lacquer on or the ink starts to bleed .
Turned out reasonable though.
