Background - I have a steel frame with an italian thread bb. Originally had a loose ball bb installed. Im trying to upgrade to a modern group and want to install a campag sealed bb to suit rest of groupset.
Problem - When I screw the sealed unit into the drive side, it goes in crooked(facing upward about 1-2mm). However it goes in easy with no force. When i put the NDS cup on, it wont go past the bearing, unless I apply some force to lower the sealed unit enough to fit the NDS cup over. This results in the bb spindle not moving at all because of the pressure on the NDS bearing.
Questions
Anyone come across a similar issue?
Will facing the bottom bracket shell fix it?
Has anyone seen a loose ball bb with a ~102mm spindle?
Ill see if I can take some photos tonight if the above doesnt make sense…
I wouldn’t think so. If it’s threading in crooked then it hasn’t hit the side of the shell yet.
I’ve only ever seen (and used) sealed 102mm BBs.
Is it possibly cross threaded?
Maybe you can try putting the NDS cup in first and maybe that will help guide the BB in straight, being careful to try and thread the BB in straight to start with (which you would’ve tried already).
See if you can get some pics of the drive side thread and/or see if the threads are good.
Unsealed bb goes in, but only 1 side of the nds cup touches the shell, with 1mm gap on other side. This isnt really an issue through as unsealed is a bit more forgiving.
Old BB cups thread in about 1cm (if that), new cups and sealed units thread in much further and if there’s any poorly finished mitering or extra sloppy welds that sit a little high it won’t thread on correctly or interfere. Nothing that 2 minutes with a dremel and a proper re-tap (deeper) can’t fix. I’ve even seen this on new frames so it’s not just the older ones with this issue.
I had an issue on a new steel frame with the cups going in further than there was clean threads.
Patience and a Dremel will work. BB chasing tool is a better solution as mentioned above.
